im going to have to read this one several times.........
but......first of all........about the creeper....the latter enjoy it more than the former......![]()
ok......the water drips are the intrusion........you said a few things that im worried about........nothng you did wrong......but man......thats an expencive boat!![]()
ok.....lets go over the "crushed glass section of the hull"......is this where he repaired the hull and applied the keel gaurd?
and did he do any work to the interior of the hull at that time?
he didn't do any work not for a bid of $1000 for 20 some inches of keel repair
now.....the fiber glass "holes" or where the matt lifted..........this is called de-lamination......and in fiberglassing.....de-lam is a failure.....is the matt that they added a chopped strand kind or a heavy woven looking thingy?
x
lift'd is the wrong word,, lets see if i can clearify,, you lay out a heavy matt
and the surface is not straight a section of it will lift causeing a fold ( a carpet not lay'd out flat ) the lift'd part was like an inch some times 1/2 inch at the outter edge, the entire matt was completely coat'd with resin and very strong,, grinding out the lift or hump would in my eyes weaken the floor, so i simply fill'd the void with resin ,,this keel section of the floor is no where near flat it's a steep angle
ok....now......when you cleaned and fiilled the "air bubbles" with resin or seacast.....did you grind away the area first?.....(prep the surface)
x
no grinding , no air bubbles ,,this keel stringer was completely wrap'd in a heavy matt and glass'd befor it was lay'd into the keel when the boat was built , then a matt was use'd to make the stringer part of the hull , it was this matt that had the wrinkles in the outter edge
grinding can sometimes cause air bubbles in the origonal substraight to "expose them selves".....this is good because you can now see thiem to repait them.........i cant figgure out if the water is from a bad layup from the boat yard, and that the boat guy missed it because he didnt do the repair from both sides as this type of hull repair uasually would, or if the tremendous amount of water coming in is from a totally different area.......
x
ok the boat guy,, only redid the section of the keel on the out side 20some inches long,, all he did was grind the outter jell coat and crush'd fiber matt down till it was solid , the crush marks were length wise with the keel , when we start'd to grind the glass it was evident the matt layers had an air gap between them from the factory , if it had been solid none of this would have happen'd , also if more rollers would have been use'd up frt the weight would not have been so heavy on one spot , a single roller suport'd more then 1/2 the entire boat weight on the trailer
seriously....the amount of water your talking about is not a leak......its a freeking river! and it should be apperant unless its covered up by somthing......(like a keel gaurd).
i think we need pics......you might have to rip out the keel gaurd.
but.....when posting pics.....after you up load to photo bucket....resize to 640 x 480 then copy the img tag..........and just past it in your responce.......other ways you get those thumbnails and they arent really big enough to see areas we need to see
