jpmurphy
Thread starter- Joined
- Jan 14, 2009
- 358
Getting ready to clean the oxidation from the hull of my 87 Alum Gregor I ordered 3M Marine Alum Restorer & Polish. This evening I started on it. Read all of the directions 3 times just to make sure I was attacking this beast correctly. Room temp @ 70. etc etc etc etc...
Pic #1 is the before.
Pic # 2 is the same section after applying and polishing by hand. Oxidation is not removed, but the shine ain't too bad, especially on the welded seam at the corner of the transom. This is not what I was hoping for.
Pic # 3 is after I lightly sanded same size section, hand rubbed with the compound and then machine buffed. A lot of the oxidation is gone, not all. The compound left a darkish coloring that I can't get tottaly cleaned off. I thought perhaps the compound was pulling some of the color from the clean towel I was using so I changed to a white towel with the same results. Still a darkish coloring, still unable to remove it all.
I purposely started this below the water line in case I ran into a problem. Glad I did !
Now, before I write to 3M and show my Irish, does anyone have any suggestioins ? This compound is a little expensive. So far I've got 50 bucks wrapped up in the compound and the polisher. Hate to waste more money.
