Seadooman03
- Joined
- Jan 31, 2009
- 48
Hello,,Im having issues starting my engine. Its a 97 Volvo 4.3GL penta engine, number 4110147360. I have not been able to get spark when i pulled a spark plug out and grounded it to the motor... It seemed as tho it wanted to start at one point, then it just didn't follow ignite. So far i have done a few things to rule out any issues
-battery is new
-Compression is 150 across the board on the 3rd stroke
-Fuel pump works, engine is getting plenty of fuel. (works during ign too)
-Newer wires on it
-New Plugs
-Choke on carb is in full operation
-Also, i read about the coil and the purple wire, i had no voltage there with the ignition on? It seems as tho all my breakers are in check, however im not 100% sure to rule those out.
I noticed some sort of new wire installed that seems to be ribbon like (Picture A), hooked up to a plug (picture B.) That's obviously not form the factory, also i heard engines requring some sort of igntion upgarde, not sure if this was it.
Picture A
Picture B
On the back of my distributor there seem to be 2 areas for a harness to clip in, I only have 1 harness, the smaller clip with the pink wire...(picture C).
Picture C
The coil i checked, and its exhisting clip, with the purple wire.. (picture D)
Im not exactly sure as to were to follow the problem back too. Im assuming the tether switch cuts ignition, and the clip is installed in that, im not exactly sure how to test it for failure tho. Any information would be much appreciated, ill check back and fill in the blanks in case i missed something. I hope I was descriptive enough explaining my situation.
Thanks in advance
kris
-battery is new
-Newer wires on it
-New Plugs
Picture A
Picture B
Picture C
Thanks in advance
kris
