Re: Johnson lower unit
If the puller that Dhadley is talking about is the one that I think it is, its also a flywheel puller. Its a stock OMC/BRP item and can be ordered through your local dealer. I paid about $70 for mine about 8 years ago. I don't know the current price, but this puller is very much worth having. The main advantage is that it is designed exactly for the OMC products - you're not buying something that you have to hope will work. You also will not have to go on multiple "missions" to the local hardware store to get the right size/grade bolts for whatever removal procedure you are trying to do.
I highly recommend buying this tool.
