Re: Impellers
If you have done mechanica work, this is a piece of cake.
1. Remove the gear shift lever pin - it's under the carb;
2. Loosen the bolts holding the lower unit and carefully pull it down.
3. Once you have it done, take of the bolts of the water pump - they are round the driveshaft, pull up the water pump clean the residue of the gasket under the plate, inspect and replace the plate, then fit the impeller with the drive pin bending the impeller plates the wrong clockwise direction, when fitting the housing and do everything back.
