ExUSCG-QM
Thread starter- Joined
- Jun 5, 2007
- 9
I've been reading threads for days trying to figure this one out, so if you know of one, please point me in the right direction.
I have a 1987 Imperial 18'4" with 3.0L GM (#B486968) and Alpha 1.
It's in fair condition for it's age and I've had it for two years with no problems.
Now I have an intermittant problem starting it. The engine is firing while I crank it, but when I let go of the key, it quits. I've gone through all of the troubleshooting items that I can find and this what I've come up with.....
The coil is only getting power from the starter while cranking. When I let go of the key to the "run" position there is no power to the coil any longer. I put the test meter on the coil + side and this is what's actually happening. So I tested the key switch and it works fine. Is there an inline fuse someplace that is stopping the power flow? As I said, this is intermittant so a fuse doesn't seem like the problem. I can start it five times and the sixth time I lose the voltage. I'll take some readings for an hour and all of a sudden the voltage is back without me making any changes!
One last point to make....the previous owner replaced the points with a Pertonix Ignitor. I didn't know how old it was so I replaced it yesterday. This did not fix the problem, but thought it could have something to do with it.
Thanks for any help,
Bill
Bill
