StevNimrod
Thread starter- Joined
- Dec 13, 2008
- 343
Late last year I posted about doing a Vortec head swap on my 1994 Wellcraft Excel 26SE, currently powered by a 5.7 Merc (SN OF276159) and mated to an Alpha 1 Gen 2 http://forums.iboats.com/showthread.php?t=287468. The general consensus, at least to my eye, was that this swap wouldn't do much to help pushing a boat that weighs a little less than 5500 lbs fully loaded.
A few weeks ago I came into a 5.7L GM engine out of a 1998 truck (4 bolt mains) and I've decided to explore going the 383 route.
I've read through a few posts and see that there are people with some experience with this. I tore the truck motor down last weekend and the block is currently at a local machine shop ready for cleaning and checking. When I dropped off the block, the owner suggested forged crank, forged pistons, and exactly an 8.5:1 compression ratio.
Is this a hard and fast rule, or does anyone have experience going with non-forged cranks and/or pistons? Also, how much leeway is there on the compression ratio? I looked up the Merc 377 and I think it was a 9:1 compression ratio. Going down to 8.5:1 in a forged piston (4.030 bore, 5.750 stroke, 5.7 rods) limits me to an SRP piston with a 31cc dish (at least from what I can find), so I'm wondering what other experiences have been had doing a 383 (and hopefully having it work).
Also any cam advise would be appreciated. I have a GM cam laying around (the part number is 14097395 and specs are duration at 050" I:196 E:206 Lift I:431" E:451 with 1.5 rockers) that is the cam in the crate GM HT-383 motor. Is this any good for my intended use or should I seek life elsewhere?
I think Bondo mentioned putting one of these together so I'm hoping he and others will chime in!
Thanks in advance.
Thanks in advance.
