starsnstripers
Thread starter- Joined
- Nov 30, 2007
- 1,330
Well, gone from Mercruiser to Volvo, Looks like a nice rig. This is a 1988 Sun Runner with a Volvo 4cyl AQ 151 B and a 290-A Volvo Drive. (1) a. Is the 151 the HP rating or Cu In? b. What is the HP? (2) It has a closed cooling system would it be a half or full system? (3) Has a raw water pump on front of engine, Does the drive have one too? (4) Where this engine has an overhead cam and a timing belt, Wouldn't it be ok to take a auto engine and put freeze plugs a marine head gasket and put the cam and head on it with the marine accesories and call it good? Thats what it looks like someone did to it. I have the original Block, they cooked a piston. I know the auto yard thats painted on the block. The guy i got it from said he tryed the boat once and it started to get hot so he stoped running it put it away and now i have it. He said he didn't know if they did the impeller in that raw water pump so maybe that's what happened to the original motor. The original motor looks saveable to me. I may rebuild it anyway. as small hole on edge of one piston and a little roughness on cyl. I think a honing and new piston could do it, but i think i'm going to do a complete rebuild. However i'd like to use the boat so back to the car motor thats in it. I'd have a good start if these questions could be answered. First i'm going to pop the cover off that raw water pump and check the impeller. Thanks any of you Volvo guys.
