- Joined
- Apr 17, 2002
- 71,516
Re: New Volvo Owner (info needed)
Ayuh,... 1st off,... I don't know that motor real well,...
That said,...
You need to find an oil pressure port in the block,+ get a switch for say 4psi or so,+ run the igntion power thru it...
Hopefully on that starter there'll be 1 of the small studs that's Powered when the starter engages,...
That's where you'll run from to the fuelpump for start-up purposes,...
Let go the Key,+ it'll draw power thru the Switch you put in...
That said,...
