tachometer
dieselcat
I was and still am having tach issues,my motor has the 3 wire rectifier part# 582399,where would i hook the tach sending wire to?I currently have it hooked up to the yellow/grey wire from the stator and at idle it reads around 2000 rpm or a little more.which is at least 1000 more than what it really is.Any ideas?
Thinking motor is an 1987 rude 88 spl
F_R
Re: tachometer
You are supposed to use the yellow/gray, but it really doesn't matter which yellow wire you use. You have set the switch on the back of the tach for the right number of poles, haven't you?
dieselcat
Re: tachometer
If i remember right it is set on 6P,is this right setting?
