volvo overheating
jwindham
I have a volvo penta AQ 131D with a 275 drive. Does fine at idle speed but gets hot at higher speeds. I have installed a new impeller and thermostat. I would think that since it cools down when at idle speed it is pumping water, but not enough. I do not know where to look from here. I ordered an engine workshop manual, however it has next to nothing about the cooling system. I would appreciate any suggestions.
Don S
Re: volvo overheating
When you say higher speed, I assume you mean on the water and getting on plane instead of just higher rpm that it overheats.
Several things could cause the problem, plugged up exhaust manifold not allowing enough water flow at higher rpms, or even a defective thermostat, or partially plugged heat exchanger.
One of the places that typically causes a problem when on plane is the water hose connection on the outdrive. The tip corrodes away right at the hose and sucks air when on plane. At idle (Off plane) it's under water and allows the pump to work normally.
jwindham
Thanks for the advice. When and if the wind stops blowing I will get on the lake and see if it is sucking air.
Jerry
Don S
If it's out of the water, go back a pull the hose and see if things break loose.
jwindham
Don, I found the air leak, it is leaking between the top of the intermediate housing and the suspension fork? (bracket that supports and lets the unit swivel) under the hose connection. There must be seal leaking. I do not know how to get to the seal. It looks like you have to take the unit apart. Sorry I don't know the name of the parts, hope you can understand all this.
Jerry
jwindham
This is an old thread, but I found an air leak between the top of the intermediate housing and the supension fork. I need help. I do not know how to fix it.
captmello
I have the same issue you do and have been fighting it for a while now. I'd start by replacing the gasket under the hose fitting on top of the intermediate. That is where the seal is made.
How did you test it to determine where it was leaking from?
jwindham
I used a garden hose to force water back from the sea water pump (To see anything was clogged up) and noticed water leaking. Not from the hose connection or gasket but under the supension fork where the unit swivels.
captmello
Ya, sounds familiar. The gasket under the hose connection is supposed to make that seal. Even though it leaks below. Like I said mentioned before, replace that gasket and see if it helps.
Let us know what happens.
jwindham
I am waiting for parts. I think you are correct. The bushing was bad. Will let you know when I try it out. Thanks!
captmello
So, did you replace the upper pivot tube bushing? that's apparently what I'm up against.:confused:
jwindham
I just got the parts today. It has been 20 days since I ordered them. I am going to replace the bushing, it was gone except for about 1/8 of it. I still do not know to replace the bushing. It would help if I knew what to take off. I guess I will start taking parts off until I get to it.
captmello
