140 water pump
apache61
I have a 89 140 V4 XL 25" before I got the motor someone else had put a V6 case on it, and it was pumping water fine. I put on a new used Lower Unit, and put in a new water pump kit. It will not push water up to the motor. The pump is working it pumps water out all over the the place on the lower unit/ the mating seam ect. I dropped it again put it back up same thing. Whats the secret to getting the water tube to go in the pump nipple.
Thanks Jim
Dhadley
Re: 140 water pump
The 25" 1989 140 came from the factory with a V6 style gearcase. It's not a true V6 lower unit but it is the same size but a different gear ratio than a true V6 or a true V4 unit. The prop you had on the old unit will not fit on the new V4 unit but probably wouldn't be the right pitch - assuming the old prop was right.
As the unit goes up you'll have to make sure the tube goes into the guide in the pump housing.
mhg
Re: 140 water pump
When I changed out the pump on my 140, I found
that I had to get it the lower unit in place then lower the
tilt so the engine was straight up and down.
I then could get the 2 shafts and the water tube to line up
I then could bolt it into place.
As to the thing about the V4 versus the V6 case thingy,
from what I have found is the 20" units got the smaller case
and the 25" units were given the larger case
I know how frustrating this is. when I first started getting parts
the dealer just asked me which case I had
Duh. Had no idea.
the easy way to I.D. is it will have 13 tooth shaft or 15 tooth shaft
M.
apache61
Re: 140 water pump
As for the V4 and V6 case got that all worked out the case that was on the motor was a V6 case 25" with the V6 gear ratio so I picked up a 25" V4. I am have one heck of time getting the thing to pump water.
apache61
Re: 140 water pump
Update,
I have been out of town with my Job from 10 April till last Fri. Put a V4 foot on it and took the boat out Saturday morning and got 61 mph (gps) out of it and it, and it handles great. I think I will paint it this fall and plan on keeping it. Looking forward to a lot of time on the water.
