Re: vro or no
VRO conversion w/ pump still working
if the fuel side on your Pump is still working it is very simple. unplug the 2 line harness going to the oil tank, unplug the 3 or 4 wire harness, going to the Vro pump. cut and cap the oil line going into the motor. add oil to fuel tank, mix well, then remove fuel line at top carb, catching gas in a container, pump the fuel line bulb until you get premixed gas to the carb. you can tell as it will change color. put line back on carb, and go boating.
This is Dhadley point of view on the subject.
Your 2001 motor did not come with a VRO pump but an OMS pump. Disconnecting it will disable some of the best protection systems available. With it working it will detect a fuel restriction, a possible engine killer, and compensate by pumping more oil. That won't happen with the oil side disconnected. It will also let you know if you're low on oil or if the carbs are not getting any oil at all. Neither of which you'll know about with the alarms disconnected. Well, you will know eventually...
It is your decision to make.
or completely replace with this.
http://www.iboats.com/Sierra_18_735...z.36857--**********.884798459--view_id.174138
