aristocraft
Thread starter- Joined
- Mar 5, 2008
- 131
hey everyone. there are many questions pertaining to the foam in the boats. i am posting this now for a few needing help at the moment, so i hope you guys read this. Flotation is required by the coastguard. closed cell foam more specifically. unfortunately all foams will eventually absorb the water if left immersed in it. even new foam. so we are talking about boats 40 years old here, some have no issues, some do. So whats the difference? well its all in how the boat is kept. Boats that are kept dry, and covered generally will never have a problem. All the boats i have ever had to fix were stored with no cover and the nose pointing downhill, creating a giant bathtub/mosquito hang out. over time closed cell foam will absorb the liquid around it. once the foam absorbs the water, you are in for a job. not a life ending job, but a job no less.
First you will want to find out if you have saturated foam. there are a few places to check. one is in the ski locker in the back there are two holes. the one on the side has a tube for the blower running through it, but sometimes you can get around the edges and check the foam there. the other spot would be under the seats, you can sometimes access foam, although this tends to be a high spot. the best location for checking on your foam is under you carpet in the rear. unfortunately this involves a little work. you will need to pull the carpet up between the back seat the the middle seat. once this is taken up you will see where the original foam was poured in. on each side a 3 inch hole was cut in the floor and the foam was poured in. then a plug was added and it was glassed back up. get the plug out and you have good access to the foam below and you will know instantly when you poke it with your finger if its saturated. if not, good for you. if so, then read below.
fixing the foam. well you will first need to remove the carpet on both sides between the rear seats and the middle seats. then comes the cutting fun. the easiest place to cut the re-glass later is just inside the recessed area the carpet rests in. cut an inch or two inside the carpet so that your beautiful glass work later on will be covered back up with the carpet. so by now you should have two giant access holes to the foam. I have no best method yet for getting it out. it changes every time. but generally it involves a normal hammer and giant screwdriver and just start breaking it out. i also use the hook end of a crow bar to help grab it out from up under the hard to get to places. once you get it out. let it air out, then re pour new foam. glass in the cut out pieces from earlier, and re-glue carpet. good job your now done.
this should get you all on your way, and I hope it helps many along the way. for parts and info let us know. thanks
www.aristocraftboats.com
