Omc Sterndrive Tilt Problem
gooders
Re: Omc Sterndrive Tilt Problem
Thanks will look at connector first. Hopefully will not have to open up throttle assembly, cant believe my luck cost me ?170 for new relay so I know thats ok! Think it going to be a trial and error job w ill let you know how I get on.;)
gooders
Just reading your post, you mentioned the two red circuit breaker buttons? Am i missing something? I know there is a breaker on the relay block, are there more! My engine is 1989 did they have them fitted that early ?:confused:
boatguya1
Not sure, some of the early cobras had the two big fuse holders mounted on the rear stbd side of the motor instead.
James
gooders
Ok, looking at the engine bow to stern. My connector plug is situated on the port side. If there were more circuit breakers what would they look like. There is a heap of wires in that area but mostly running from the distributor,coil. and what I think is a voltage regulator. Sorry to be a numbskull but still learning about the engine :confused:
gooders
Just looking ahead, if the switch is faulty or the wires in the throttle are broken .How difficult is it to remedy?:confused:
boatguya1
As for the circuit breakers look for red buttons about 3/8" diameter if you see one push it in.
It depends on the remote how hard it is to change the switch.
James
gooders
Hi again. Checked the plug near to the engine.Definitely power from there to the motor so problem is from plug to switch. However, when I jumped the terminals on the plug to activate the motor all I could hear was a click, not unlike the noise a solenoid makes. Any ideas why motor wont work, I did run a feed direct from the battery and that worked it fine.Got to admit I am stumped?
Don S
I would suggest you go back up to the link I posted earlier, go back through the troubleshooting section again. This time post your actual voltage readings for each step, 1 through 6.
Then we can tell you where your problem is.
gooders
Ok, will be back soon.
boatguya1
I didn't read the trobleshooting portion so maybe it's included, But make sure both ends of wires A&B are connected securly and free of corrosion.
James
gooders
Hi guys. Success, found one of the connections to be loose so sorted it now. BUT! Have you ever heard the phrase 'just when you thought it was safe to go back in the water'. Operated the sterndrive up and down, motor running fine but sounded a little strange. Looked overboard and saw a small puddle of red hydraulic fluid. Oh Great, just great! Anyway had a good look and one of the hoses appears to be split. I think its been rubbing against the cowling that goes over the drive. I think the fluid may be low and the pump was begining to starve. Anyway the problem hose, as you stand at the stern looking forhead, its the one on the starboard side cylinder on the tilt up pressure side. The other hose has a metal pipe extension that one looks ok, gather thats the down stroke. Guys how difficult is it to replace this hose, any advice would be grateful.
And thanks to all for helping me with the tilt problem.
gooders
Hi guys. Still need some help re the hydraulic hose issue. I have studied the manuals all morning and can see that the drive needs to come off. How hard is it from there and if I dont touch the engine will the drive shaft go back in easily without the use of an alignment tool?
boatguya1
It's kind of a pain in the ***** to do. Get a Manual and follow directions. You donot need to do alignment to re-install the drive. If you remove the bellows to access the lines put a new one on.
James
gooders
Thanks for the advice. I was worried about the alignment bit. Really appreciate all the advice, now time to get to it.;)
busaboy
i got a 78 larson that the upper stern had seized up lower is fine i broke the control cable trying to shake it lose my main question is...is it easer to rebuild or find a used one?
