TRACKMAGNA17
Thread starter- Joined
- Mar 16, 2009
- 8
Ok I have a 1982 evinrude 88 with a 17 pitch prop on it. The boat is a 17 foot deep aluminum boat. Previousely I had a 90hp force motor with a 13 by 17 prop that would run at about 46 mph. Im wondering if this is all the I can expect out of the evinrude motor or not. The force motor that was previousely on it also had a scored piston the entire short time that it was on there and still ran faster than the evinrude. I did purchase a used tach and installed it. Now I question if it works correctly. At idle it reads about 1500rpm and as soon as I get the boat to plane 3/4 throttle the tach reads over 6000 rpm. I moved the dial on the back of the tach to 4cycle when installing and hooked it up the the grey wire that comes into my shifter box. Am I missing something here? Just trying to get up onto plane faster and a bit more speed cause it really slows down when you add another person and water in the livewell. Any help would be greatly appreciated.
Thanks,
Al
Thanks,
Al
