Maybe the dumbest outdrive question ever
mncp8r
Asking this question here to save having to watch the local marine mechanic double over with laughter... I have an 06 Sea Ray 250 SLX with a Merc 320 HP engine and a single prop (Alpha 1?) outdrive. Is it possible to upgrade to a Bravo 3 with duoprops? :redface:
ShaneCarroll
Re: Maybe the dumbest outdrive question ever
It's possible, but awfully expensive, and not that great of an advantage for the money, IMO.
mncp8r
Wow thanks for the super fast response... What's "awefully expensive"? $2K, more????
slasmith1
if it is a bravo drive it is the cost of a lower unit and props plus labor.
if it is an alpha drive you need to replace the whole drive.
Don S
I seriously doubt you have an Alpha I Gen II outdrive on a 2006 320HP engine. Since Merc has a 300 hp max on the Alphas. NOW, assuming you have a Bravo I or even a Bravo II single prop outdrive, it's still going to be expensive. The SS dual props alone are around 1500 bucks. then a new lower unit is expensive compared to the props. Usually you can find a new Bravo III lower for around $5500
Now, if you actually have an Alpha I Gen II, you would have to replace EVERYTHING but the engine. Transom shield, and outdrive.
Now, you are getting into big bucks, and a lot of work. Way over you 2K limit.
Ayuh,... Add another Zero,+ you could stay under Budget......
