chrishayes
Thread starter- Joined
- Apr 9, 2009
- 691
I am about to order all my supplies for my floor redo. I went and bought two sheets of 1/2" ACX ply last night and have the heater blowing on it. I have ripped the deck off, removed the motor and ordered all the replacement parts for it. Then this weekend I will be starting on removing the cap so I can get to the front deck portion and take a good look at the transom. I will still need to grind out whats left of the stringer.
Should I leave the bottom 1" or 2 to allow me a groove to help with the stringer replacement? You know, keeping them parallel to each other?
So, the boat is a 73 Wellcraft airslot 165, the motor is a 1974 merc o/b 1500. The boat is 16.5' long and I have not measured the width but I assume it is less than 50" and narrows down quite a bit at the bow due to the tri hull design.
How much FG and what weights do I need to purchase figuring that the transom is likely to need work as well(feels solid, still need to do cores when cap is off).
I am leaning towards Epoxy due to having less layup layers from what I have read and the inherent strength that it adds. Budget is not a huge concern because I only want to do this once and a few extra bucks arent going to be noticed a year from now, but the lifespan will. Make sense?
Is there a formula to figure out gallons of resins and FG for either using Poly or epoxy to allow me to compare the differences in cost and estimated time? I am terrible at math so it would need to be fairly simple...
ANy help would be much obliged. TIA.
Chris
h
Chris
h
