64FAIRLANESC
- Joined
- May 13, 2009
- 8
I Have A 95 40 Hp Force. The Trim Goes Up And Down Fine. The Problem Is That When You Go Up I Can Stop The Engine By Putting Very Little Pressure On The Lower Unit. When Going Down It Works Find. There Is No Leak Down If It Sits Up. I Was Thinking It Was In The Check Valves. I Took Apart The Two Assemblys And Foud That One Of The Seals On The Popit Valves Was Installed Backwards. I Corrected That And It Did Not Change. It Seems Like It Has Blow By In The Directional Valve. Am I Close Or Not.
