Frustration Questions
bktheking
Re: Frustration Questions
I just hooked up mine with a toggle switch but a horn button (momentary switch) will do the same thing.
samo_ott
Possiblity???
Would it work if I put the black wires from each cylinder so that they are attached to a spring button similar to what you used as a horn button that is grounded and when pushed, grounds out the wires so the engine will shut down. I don't have thw "M" on my ignition switch. Just want to make sure that I won't fry anything by doing this.
Thanks for all the help. Hopefully this will work and I can be fishing...Finally
Yuppo. should work fine.
wadeseward
Put the switch in last night, engine kills, I'm off and running. Like a kid in a candy store.
