Possiblity???
Would it work if I put the black wires from each cylinder so that they are attached to a spring button similar to what you used as a horn button that is grounded and when pushed, grounds out the wires so the engine will shut down. I don't have thw "M" on my ignition switch. Just want to make sure that I won't fry anything by doing this.
Thanks for all the help. Hopefully this will work and I can be fishing...Finally
