StevNimrod
Thread starter- Joined
- Dec 13, 2008
- 343
I have a 1994 Wellcraft Excel with a thru the transom exhaust system made by Stainless Marine. Save the comments on loud pipes - it was like this when I got it (not that I'm saying it's a bad thing either).
While I'm in the process of painting the bilge (engine swap so why not) I figured I'd track down a small leak I was having last season. It appears the block off plate was not sealed correctly and had a slight leak. I have a new style plate and the seal for it as well as a full complement of Merc manuals. The manual (which I don't have in front of me) states that the procedure is to simply install the seal and plate, then torque the screws to 23 ft-lbs (or whatever it was).
My question, to those of you with this setup who may have done this before: should I use any type of sealant or adhesive when installing this? The guy at the Merc dealer's parts counter suggested bellows adhesive, my marine mechanic suggested 5200 or Life Seal, and I also have some Quicksilver Perfect Seal laying around. Once I get the new motor in I won't have access to the plate so I'd like to get it right the first time. I don't want to install it without any sealant and have it leak, and I don't want to install it with sealant only to have it leak as well.
Sorry for the novel fellas. Thoughts?
