Mike in CT
Thread starter- Joined
- Mar 27, 2009
- 24
hello again to all. just to refresh, i picked up a 74 mfg caprice. it has a 165hp straight6 and an omc i/o. well i got it running. it seems to run pretty well. there is a drain bolt on manifold that was stripped out that i knew about that needs fixing, no biggie, but i have a leak in what appears to be an coolant port that is capped off on the outdrive. when running was comes out pretty good. same port on otherside is dry so i'm guessing it should be as well. appears to have a gasket with gray goop behind cap. i was just going to remove it and try fixing with permatex, but i thought i might take a vid and get somefeedback here. i've never seen gray permatex so i did not know if i needed a special type.???? i will try to post a link to my photobucket link below
http://smg.photobucket.com/albums/v249/mikes88troop/boat/?action=view¤t=MOV03003.flv
