3L alarm in rough water
TBarCYa
Last weekend I got caught in some rough water and the alarm would beep briefly when the boat hit a wave. The engine didn't cut out and I was wearing the lanyard. Everything ran perfect but the alarm would beep. Any ideas?
kk lowrider
Re: 3L alarm in rough water
Could be your depth alarm with the sudden changes in depth if you have one . Just a thought
Bdt 1967
Sounds like a lose connection.
TBarCYa
I was thinking about the loose connection issue and I did have a problem early in the day where a connection popped off the ignition switch but it didn't appear to be loose when I was getting the alarm.
I guess as long as it's not telling me that something is wrong with the drive system, I can take some time to look for it.
Thanks.
cooter2506
Check you gear lube bottle. If it is real low and gets sloshed it may set alarm off.
Fun Times
Could be low water pressure at the sensor do to airing out the boat/drive in the rough stuff, And some engines have a over speed horn too. what engine set up do you have?
