Timing - Merc 7.4L MPI 1999
Joker757
Can someone provide me with instructions on setting the timing on a 1999 Merc 7.4L MPI? Also what tools will I need. Thanks.
HT32BSX115
Re: Timing - Merc 7.4L MPI 1999
Howdy,
You evidently don't have a service manual. That's the first "tool" you'll need.
http://www.boatfix.com/merc/Servmanl/16/16cov2_1.pdf
Also, a timing light will help. The manual indicates what other "stuff" you'll need.
Regards,
Rick
Joker757
I have the SELOC manual however I didn't see the procedure in it. Thanks.
HT32BSX115
The Seloc manual is best used for starting your BBQ, or fireplace.
If the Boatfix link doesn't point you to the right manual, (check engine serial number.... year model doesn't mean much) and go to the "Adults Only" sticky in the thread list for this forum and look in the "Manuals" section.
Joker757
Joker757
I clicked on the red boxed area and it takes me to the manual however clicking on each chapter does nothing.
HT32BSX115
Talk to the Hand!
Talk to the Hand!
As you roll your mouse cursor over each line, it will change to a "hand" or other sort of "pointer". When it does, you can click and open that section.
Don S
Re: Talk to the Hand!
#16 is the wrong manual,. IF your engine is actually a 99, or even a 98, you should be looking at the specs and procedures in manual #23.
Don S
I don't think Boatfix has #23 in a down-loadable format either.
Then why try to use boatfix???????? They only have 4 engine manuals (I think that is the right number) but the link in the Adults only has them all?
You can also download the 16 manual in one click in the Adults only thread, not one section at a time. The manual was changed.
