Re: Why won't you start?
Oh, Oh, I read your first post too fast.
Fuel leaking out of a carb is not a good thing. That cyl is flooding and already has TOO MUCH fuel in it.
Clean all carbs and make sure that the float height is set according to the manual. You may need to get a carb 'kit' and replace the needle or seat to be sure that it seals off when the carb is full.
Then try holding the choke while cranking, just long enough til you get the first fire.
