1956 5.5 Johnson Carb Help
jaboatman
I am new to the forum but hopeing someone can help me. I have a 1956 Johnson outboard a CD-15 I think. I got some bad fuel mix (dirty) and believe have clogged up the carb. I know a liitle bit about engines (lawn mowers) but have never worked on a outbaord and am kind of scared to with it age. I was hopeing someone might be able to give me some ideas as how to take it apart and what to check. I know on must lawm mowers it is usaly clogged idle jets I am assuming the same for outboards.:eek:
Thanks
P.S.
Engines turns over with fuel straight to plug holes, thats why guess card issue.
jaboatman
Re: 1956 5.5 Johnson Carb Help
Just an update motor is a cd-13 Johnson Thanks
moldeck
:pI have been in a 54 3hp and a 57 5.5 and they are very similar to the two lawn tractors I have had apart. You should be just fine.
tx1961whaler
There are pretty good instructions here:
http://forums.iboats.com/showthread.php?t=244013
Be very meticulous about cleaning it. The passages and jets are very small on these little carbs and it's easy to miss a piece of crud in a passage. I soak them, use compressed air and spray carb cleaner to get everything out.
samo_ott
They are easy to clean. It will take you longer to re and re the carb then it will to rebuild it. But you should get a carb kit. They're only about $20.
If you want, I have the parts manual for the '56 Evinrude 5.5 which is basically the same engine. If you want to PM me your emaill address, I can email it to you.
birddog681
Steve,
I would love a copy of your parts manual for the 56. I believe mine to be a 56 but the data tag is missing, any thoughts on that as well.
Thanks - Dave
samo_ott
Post a picture of the engine if you could. And pm me your email address for the manual.
