1989 bayliner lost gauge power wont start please help its fixed
chuckz
Re: 1989 bayliner lost gauge power wont start please help
Bet you that lose brown wire is the ground for the gauges. Start checking the ground side. If you measure five volts, there is something in series with your circuit. Again, probably a bad ground.
bayliner 2.3 1988
i check it out thanks that would make since
bayliner 2.3 1988
:Di found it it was a 50 amp fuses blown in the motor run good now that replace everthing thanks a for all the help guys :):D
Nandy
Two questions,
Do you have a Volt Ohm Meter?
Do you know how to use it properly?
Dang Bubba, I was going there. If you dont know how to use a voltmeter I hate to say it will be better to get someone that does. This dont sounds like a complicated trouble if you know electronics and are handy with a voltmeter.
Do you know the battery to be good? I read something about you jump it and it work? I could not understand you well.
Use a good known battery...
########## Im a bit late, glad you fix it!!! ##########
Tnriverrat
Re: 1989 bayliner lost gauge power wont start please help its fixed
I had this same problem on my 87 capri,Mine turned out to be all the conectors on the wire harness,I bought some contact cleaner spray and have not had a problem since,But i do however have a starter problem i cant seem to fix...Keeps staying engaged while the motor is running,Doesn not do it all the time ...puzzeled
