1975 Checkmate V-Mate II Restore
archbuilder
Re: 1975 Checkmate V-Mate II Restore
Nice to see your post again! Looking forward to seeing your progress!
bigredinohio
Did some more work today. I cranked on all the heaters this morning until my garage was about 90 degrees. With all the bad core now removed, I set the new in and now my core repair is finally complete.
Since I had time to kill today, I finally got around to scraping the adhesive/sealer off of the hall that seals the cap to the hall. I ended up using some carb cleaner with a kitchen scratch pad to get the remaining bits off. After that, I decided that I'm most likely going to redo my dash completely so I made some plugs to fill in some holes using some 3/4" plywood. I still need to do some work with the big hole but I didn't want to mess with cutting into the dash and making a mess on my core repair. They aren't the prettiest but after they are glued in and glassed over, you'll never know there were any holes.
This evening I mixed up some pb and filled in all the gaps around the core.
Tomorrow with weather permitting, I will sand and lay a layer of cloth glass over the two upper sections.
archbuilder
Looking good, she is a sexy boat, get her running again!
bigredinohio
Today, I glassed over the repair forward repair area.
Not to worry, there is excess glass that didn't need wetted out. It will get sanded off.
bigredinohio
Then I took 1708 and covered the entire back section stopping short of the new glassing in the front. I will let everything set up and cure then I will sand the front and just enough of the 1708 that I laid today to overlap. Then I'll be ready to install the stringer. :D
archbuilder
Nice looking job! That brings back fond memories....of itching! :eek: What are you using for stringer material?
bigredinohio
LOL...the itching isn't too bad with the sanding. I have (2) 1/2 pieces of plywood that's glued together and pre-glassed.
archbuilder
I think I remember that now. Your work looks really detail oriented, nice job.
bigredinohio
I finished glassing the forward core repair with 1708 yesterday. My core repair is officially over, unless there is an issue down the road.
Today, I trimmed my stringer (or floor support if you like) and it's finally in the boat. The process I used was simple to get the original height. First, I scribed the bottom where it seemed a little high then I cut a line down where the tabs of the original floor are. This allowed me to pull a string from one tab acoss through the line I cut to the other tab to get my height. I did this for the front, middle and rear section of the stringer then ran a chalk line across all three marks then used a circular saw to cut a nice straight line.
Afterwards, I bedded it in place using PL Premium. Once in place, I used 2x4's weighted down with some concrete block to hold in place so I could make sure it was centered as best as it could be then ran a bead of PL down the edge to do fillets.
bigredinohio
I made some progress this weekend by installing my deck. I glued it in using PL Premium then weighed it down with everything I could find. After setting it in place, I then filled in the seams with the leftover glue.
Today, I took off all the weight and scraped off any excess glue from the wood and hull. Then I mixed up a couple of batches of epoxy pb and fillet the edges. If it wasn't for the fact that it's been raining for the past couple of day, I'd have it glassed in but that will probably wait until Tuesday, if I'm lucky.
It's so nice to be able to walk on something flat in this boat for a change!
Friscoboater
Nice work man. Why is the deck so low in the hull? From the look in the pictures you wold be sitting at an angle behind the steering wheel.
bigredinohio
It's a real low profile boat. The seats will be mounted on a wood box that I need to construct that will contour part of the side of the hull. You can kind of see where the original seat mounts were before I sanded the hall.
ezmobee
Good work. That's definitely a milestone!
jcsercsa
Looking Good there Red !!! You will be hitting the water soon !! John
bigredinohio
Thanks guys! It is a huge milestone and my goal is to be on the water by July if not before.
I plan on building a wood base for the new gas tank to hold it in place. Should the gas tank need any foam board around it for cushion/protection or could I make the base slightly larger to accomodate for expansion and tack it in place with some glue? Right now, I'm leaning towards the latter of the two.
All opinions are welcome.
lowkee
What a milestone to pass! Great work.
To answer your question on the gas tank, I put a bead of PL under the tank, but if I had the chance to redo it, I'd spray some rubberized undercoating on the tank mount and anything the tank would touch. That would prevent noise from the tank bumping around and soften any blows from bouncing around. Although even some pink foam under the tank would suffice and give the added benefit of air/water movement.
You have a lot of options and it really boils down to your own preference, as my tank had no mounting at all when I removed it. It was just sitting there with 1/4" expansion area.
bigredinohio
I've started working on the seat bases. Here is the framed construction of my rear seat that will tie into the transom. Once done, I should be able to mount any size motor on this boat but for now, I'll start out with my 1500. When I'm done adding all this wood, I'll probably need a 250 hp to reach good speed.
Anyways, my 19 gallon fuel tank will be elevated in the back to give room for my bilge pump. There will be a 1" allowance on each side of the tank for adding foam or whatever buffer I come up with. The total height of the base for the rear bench seat will only 8" tall. The total height from deck to top of the cap is only 22" so I want company to be confortable without feeling like they are going to fall out. The depth of the seat will be 18". Here are a couple of pictures of what I have thus far but my pieces still need to be contoured to the hall...
Also, here is the basic construction of my front seat base mounts. I still need to contour the edges with the hall and make the tops that the seat will bolt to.
bigredinohio
Here are some updated pictures...
Roughed construction of the rear seat
Glassed the back and seat of the bench seat.
Fitted supports that will tie into the transom
