boat seems to heavy?
TBRANCH
I Have A 14' Flat Bottom Skiff With A 48spl Evirude.the Back Of The Boat When In The Water Is About 2" From Going Under.the Boat Won't Even Plain Out?any Help
Bob_VT
Re: boat seems to heavy?
Is the hull fiberglass with flotation? You might have some extra weight inside the hull from water.
A 48 should have a 14' boat moving right along. How is the engine mounted and on what trim setting? Where is the fuel tank? Is it a tiller steer of do you have controls up front?
Welcome to iboats. Post a picture of your set up.
TBRANCH
My Boat Is Fiberglass,it Has An After Market Trim Cmc I Balieve,the Motor Is Set Level With The Bottom Of The Boat.(cavitation Plate)any Way To Get The Water Out?how Do You Insert Pic.?
Andy in NY
Im going to agree with bob that you probably have waterlogged foam under the deck. my new project boat had some exposed foam, i pulled out a 12x12x4" thick piece that weighed about 10 lbs!
TBRANCH
Just Found Out The Boat Has Water In It,drilled Two Holes In The Bottom Of The Hull.what Do I Do Now?
fishon13
How is your bildge area set up? Is your floor sealed off from the bildge area? drilling holes in the bottom of your boat wouldn't be my first starting point but its done. Some more info and pics would help. Your foam is probally soaked, its time to find out cut a small hole in your deck and push on the foam if water comes out you've found your problem.
Bob_VT
Time to move this to restoration.......
erikgreen
I wouldn't drill holes in the boat to try and drain the water either... no point, and you'll have to repair the holes later.
Short answer: There's no way to dry out the foam. Really. You have to remove it.
This is a fair amount of work, but it's not hard to do. Verify that wet foam is your problem by checking core samples in various locations - cut a small hole in the deck or whatever from above, then use a section of PVC pipe to take out a core and check for water.
If you've got to take out the foam, then you'll need to do it the obvious way, but folks here can offer suggestions on how to do it properly and minimize the repairs you'll have to do after it's out.
FYI, the USCG recommends re-installing the foam for floatation, but it's not a legal requirement unless you're a professional boat manufacturer.
Erik
TBRANCH
Thanks For All Of The Help.i Was Told To Shop Vac It Out.will This Work?
erikgreen
Shop vac out the foam? Not really... it's solid stuff, even when really wet. It might work for some of it, but you'll have to manually dig out the rest.
If you mean shop vac the water out, no, that won't work except for a little bit of the water near the top of the foam, or standing water in the boat.
There's really no way around this except to manually pull the foam out. Lots of folks here have done it....
TBRANCH
Anyone Have Any Pics On How To Remove The Decking Correctly?
TBRANCH
My Boat Is A Pace Craft 14,flat Bottom Skiff.anyone Know What This Is?
Bob_VT
Well show us a picture or two and we will coach you through it. The rub rail insert must come out and the metal backing needs to be removed as a start
TBRANCH
[/IMG]
Bob_VT
Is that boat fiberglass or plastic? Nice boat and looks like it might not split........ What are the first three letters of the hull identification number?
The hull looks fairly new..... maybe there is a warranty? I would like to look the manufacturer up and ask a few questions such as construction method and what type of foam.
Is water still coming out? The shop vac might be the only method.
Now I would go the manufacturer rout first.
If you want to install a deck plate (screw in cover) I would go with a 6 to 8" one http://www.iboats.com/Deck_Plates/dm/*******.015314414--**********.589623620--view_id.373615 installed either in the deck in front of the outboard or in the back of the rear bench seat.
This would provide access to ????? foam and the inner hull.
How deep in the rear splashwell as compared to the outside of the hull?
TBRANCH
The Hull # Is Xer45004b192 Pace Craft 14'. The Hull Is Fiberglass.if You Can Find Out How To Contact The Manufactuer,that Would Be Great.i Never Could Find Out Anything When I Bought The Boat Used 4 Months Ago. Thank You
Bob_VT
Well I can not find any information but based on the id# it is a 1992 boat.
MIC:
XER Status:
Out of Business
Company:
FAIRLINE BOATS OF NORTH AMER Company Official:
RENFROW, JIM
Parent Company:
Parent MIC:
Address:
2031 SW 20TH STREET City:
FORT LAUDERDALE
State:
FL Zip:
33315
Country:
Phone:
9545257430
Fax:
9545257417 In Business:
3/24/1998 12:00:00 AM
Out of Business:
12/15/2003 12:00:00 AM Date Modified:
Type:
ImportersInboards, Cabin Cruisers Additional Address:
FACTORY: BARNWELL ROAD OUNDLE, PETERBOROUGH ENGLAND
Comments:
030602 ADDRESS AND POC CHANGE; WAS ROBT CORDEN, 1000 MAIN ST, SUITE 200-B, HILTON HEAD, SC, 29926, (803)342-3453. 12/15/03 CHANGED MIC TO FLN TO HARMONIZE MIC WITH FAILINES BRITISH MIC.
