Arrived at our lake rental Sat. night and have been working on the boat since Sun. AM. Here's the scoop: Boat is a Four Winns 3.0 OMC Cobra. It overheated first time in the water. Pulled impeller and it was toast...badly disintegrated. Replaced impeller, housing,o-ring, gasket and plate. Flushed old impeller pieces out of intake hose(pulled off at T-stat housing and back flushed, prior to installing new impeller). Now it will not draw water unless it's hooked to a hose w/muffs. Unhooked intake hose at t-stat housing and water flows only if engine is running and muffs connected. Fed a garden hose into intake hose and back fed water thru the system....water exited at intakes. impeller housing drain, and around prop....no leaks anywhere in intake hoses. It will draw if you start it with the muffs on and then slide them off while running in the water. It pumps fine until you shut it off. Then on restart it won't pump until you put the muffs on again. Any ideas? Please help as my family really wants me to spend my vacation with them and not working on the boat!
Sorry for the long post...trying to give a clear picture of the prob.
