electric start 1968 Evinrude 18 HP
mobydick
I would like to put an electric start on my motor but cannot find much information about it. I know they are available from this forum as well as seeing my same motor for sale with an electric start. I have found the actual starter motor for sale new with the gear on it but I do not know what else I will need to mount it. The wiring and solenoid are not a big deal, I can figure that out. What I am trying to find is information about mounting the starter motor. A good photo or diagram would be great because I can fabricate just about any part I need to. An actual mount would be even better because then I can just bolt it on.
Any light you can shed on this would be appreciated.
jbjennings
Re: electric start 1968 Evinrude 18 HP
If I were you, I'd look at laingsoutboards.com, or even better, place a free ad on aomci.org for a starter bracket. The bracket is the key to the deal.
JBJ
F_R
JBJ
My guess is that there are more people looking for that bracket than there were brackets ever made.
mobydick
Thanks JB and FR. The bracket in the image by FR looks like something I can fabricate. If anyone happens to have a good quality photo of the bracket on the motor, that would be a huge help.
jbjennings
If F-R says that the bracket is the same as a '58 evinrude starter bracket, I can easily post a few close-ups for you.
BTW, if you can fabricate more than one of those reasonably cheaply, you could make yourself some money. I'd buy one from you, myself!:)
Later,
JBJ
F_R
Later,
JBJ
Well, I can't guarantee it, but as far as I know the '58 has provision for the silencer bolt. Otherwise, same. As far as I know.
jbjennings
Will post some pics later today. If they're not good enough, pm me your email and I'll send you some bigger ones.
JBJ
jbjennings
Here goes!
samo_ott
Good pics Jason... You just happened to have a spare starter and bracket hanging around :) Heck, you don't need another one!
asdasc
You can get an old 18HP motor WITH electric start for that price.
thbtgold
Does anybody know how many teeth are on the starter drive? Also is there any starters out there that can be converted (brackets) to fit? Thanks
samo_ott
It looks like 10 teeth judging from Jason's pic. But I'm sure he can count em :)
if i remember correctly it was 10. i did one a couple of month back.
mobydick
Thanks for the pics JB. They are perfect. I will start on the bracket this weekend and let you know how it goes. I do not know how cheap I can make it, we will see. The collar that fits around the starter will certainly be the challenge.
jbjennings
Looks like Steve has "starter envy"!!!:D
Really, I haven't found anyone I can trust to weld the crack in that starter bracket yet. When I do I'm going to mount it and drive that motor a while to see how I like it. I mismatched a different pinion gear with the gear set on the '58 fastwin the starter fits and it has a very slight gear whine. I'm going to have to see what you guys think about it before I put any major time on that motor.
I'm eager to see your how your starter bracket comes out, Moby!
Later,
JBJ
mobydick
Unfortunatly, I was unsuccesful in fabricating the bracket. It was just too much work. I found a used bracket with a motor but the gear is not quite right. Is there a away to find out which gear I need to properly match the gear on the flywheel. As a reminder, I have a 1968 18HP short shaft. Is there a resource for new gears? I looked on the BRP site but it does not list an electric starter for my motor.
