Howdy! Just bought a 1967 Johnson Seahorse 3hp SN-82752702 Model#JM22C. When I went to p/u the unit it ran for a couple seconds and stalled out not to crank again. Then got it home and it did the same thing. Proceeded to clean the carb and put fresh gas mix in the tank. Now it does stay running and will crank on first pull but runs rough and will not rev to full power. It seems to run at idle speed and wants to stall out when you try to rev it up. The unit I was told has very little time on it and looks brand new so I do beleive the seller. Would it be the air fuel mix needle or exhaust ports? Thanks in advance! >>> JONESN
