1967 Seahorse 3hp wont rev up
F_R
Re: 1967 Seahorse 3hp wont rev up
All righty then > I replaced the coils, points and condensers and it still runs as it did before.I also broke the brass pin in the prop hub trying to get the fly wheel torqued on. My next guess is shear pin for prop,spark plug wires and checking compression correct? Anything else need to be looked at before doing this and in what order? Im having a tuff time navigating and finding parts on this site for the year I have::confused: Thanks JONESN
Compression test should have been the First thing you checked. Yes, it might have a spark plug wire arcing through where it is clamped to the bottom of the armature plate. In really tough cases, a resistance test of everything is a good diagnostic tool. I don't see where even a spark check was ever done, but maybe I missed it.
Flywheel torque is 30-40 foot pounds, although some manuals state 40-45. Well at least 40 gets it both ways. Use a strap wrench to hold the flywheel instead of the propeller. Besides, the pin is supposed to be stainless steel , not brass. Part number is 203230.
JONESN
Me and my buddy did a compression check on it today and it has bout 65 lbs. on each cylinder and also checked the spark and seems to be ample. Might I have missed something in the carb keeping it from reving > jets or mixture needle I dunno? Im stumped.
JONESN
It was a freakin .10 cent gasket in the bowl where the main jet sit's. Runs like a top now. Had it out this past Sunday. It was pushing a 15ft 4inch Old Town Square Stern Canoe at about 14mph with 2-200 pound people in it! I'm happy!
JONESN
