stephentyler20
Thread starter- Joined
- Apr 13, 2008
- 117
Hi all,
Pulled the boat out this evening to bring home for some routing maintenance/upgrades (putting the bimini on because the sun's back, new stereo components, water sealing, etc). Was only planning to have it out for a couple days.
She's been running great lately, with the only exception being the last few days I've noticed a strange problem. When going from neutral to forward, it's been hanging and not wanting to carry over to first. I had to add more throttle than usual until it grabbed, and then it's fine.
So when I pull the boat, I happened to glance at the prop and, lo and behold...
I couldn't believe it... I never even noticed! If I hadn't randomly pulled the boat, it would have sat there, and I would have run it repeatedly until figuring this out.
So my question is, what damage should I be concerned about? I assume this must be related to my shifting change. Is the line causing excess resistance for the prop, which is why I need more throttle to get it into gear? Could there be any long term damage caused? Seals perhaps? I just redid all the UPPER seals on my drive over the winter, but haven't touched the lower unit.
I'd appreciate if anyone has tips on what I should investigate while she's out. Tomorrow, I intend to pull the prop, remove the line and have a look with a flashlight before doing anything else. Then I'll probably do a quick gear lube change, which I'd typically do anyway just for good measure.
