carb problem
lennom
My 1976 mercury 7.5hp ser. #: 4554878 has had the card rebuilt but still does not pump fuel to carb. In order to keep running i have to keep pumping the primer ball on the full line to keep fuel in the carb. I purchased it used a month ago and the seller did not have the fuel line so I purchased one from basspro shop. Could the line not be the proper line? Why is the fuel not pumping to the carb on it's own?
rosser1
Re: carb problem
if carbs are right, it may be fuel pump not pulling fuel tp the carbs once primer is full
lennom
Re: carb problem
the card uses a pulse type diaphragm pump. How do I fix the not pulling fuel to carb problem?
green4themoney
Re: carb problem
your can buy a fuel pump rebuild kit for your motor, thats what sounds like the problem is, she aint drawing fuel!
rosser1
Re: carb problem
you can tear in to the fuel pump and see if diaphrams are hard, if so, they need replacing, if still soft you have other problems
