40 hp Johnson Suntracker
Pontoonfun
How do I find out what year this engine is?, Gas is pouring out the top carb screen, probably the float stuck and dirt. Are their any videos for repairing and or cleaning this issue. Carbs were rebuilt 3 years ago. new bowls...
bustermin
Banned
Re: 40 hp Johnson Suntracker
HOW TO FIND THE YEAR OF MANUFACTURE OF YOUR YOUR JOHNSON AND EVINRUDE OUTBOARD MOTOR.
EXAMPLE:.
Typical Model number (J150TLCCA)
(J)150TLCCA = JOHNSON
(E)150TLCCA = EVINRUDE
J(150)TLCCA = HP.
J150(T)LCCA = TRIM AND TILT
J150T(L)CCA = LONG SHAFT OR 20" LEG OR TRANSOM HEIGHT
J150T(X)CCA = EXTRA LONG OR 25" LEG OR TRANSOM HEIGHT
J150TL(CC)A = YEAR MODEL. THE CODE WORD (INTRODUCES) IS USED TO DENOTE WHICH YEAR THE LETTER REPRESENTS.
EXAMPLE
I = 1
N = 2
T = 3
R = 4
O = 5
D = 6
U = 7
C - 8
E = 9
S = 0
More information can be found at:
http://www.outboardparts.com.au/id/HOW TO FIND YEAR OF MANUFACTURE OF YOUR JOHNSON AND.htm
Pontoonfun
Thanks, next time I'm at the storage place I be checking the numbers.
Pontoonfun
I fix the carbs runs good, However now the shift leakage is not working correctly, it goes in forward and reverse when taken out of gear, another issue any words on this...
Installing control cables.
1. set controls in neutral and at idle.
2. manually make sure motor is in neutral and at idle.
3. on the motor end of the cable, is a trunion nut (adjustment nut) there is a retainer, on
the motor for the trunion nut remove the clip.
4. without moving anything on the motor, adjust the trunion nut (turning nut) so that
The nut sits in the retainer, and will connect to the motor.
5. connect the cable to the motor, reinstall the retainer clip.
Note: you adjust the cable to the motor, not the motor to the cable.
