Help Please 1961 75 h.p. Johnson Seahorse
slogue1963
can anyone tell me where on line that I can find manuals and wiring schematics for this motor,the model # is V4AL-13 I looked up the motor by model number and found out that it was a 1961 model, just got boat and there was no owners manual that came with the boat, also have no idea what year that the boat was made or what type it is any help would be appreciated att. is a few pics of the boat, thanks for the help if any.
jonesg
Re: Help Please 1961 75 h.p. Johnson Seahorse
neat boat! it looks original with the engine. 1961
Get the SERVICE manual and the PARTS book for sure, not the owner manual.
With the part numbers you can still get the parts at most any dealer, without the part numbers they will not bother looking them up.
http://www.outboardbooks.com/index.cfm?fuseaction=models.main&year=1961&ID=128527
I would start with a compression test. Post the numbers.
Change lower gear oil, you will probably need an impact screwdriver from Sears to loosen the drain screws.
Remove prop and check prop shaft for fishing line, lube shaft with marine grease and reinstall prop.
Examine coils, look for cracks and replace if cracked ( probably).
clean plugs or replace.
spray some aerosol seafoam in the plug holes and leave to soak, it will decarb the rings.
Remove fuel tank and flush or junk it and replace (craigslist for used tanks)
REplace fuel lines, all of them from the fill to the carb.
http://foreandaftmarine.com/FUELHOSECERT.HTM
install water seperator.!
When you get the manual order rebuild kits and rebuild the carbs.
watch this, its very simple.
http://www.youtube.com/watch?v=o5cxBMDezuU&feature=channel_page
hope that gets you started.:)
jonesg
Post those pics in the restoration forum, someone might very well have all the info on that boat.
you did not get a title or registration. get those before investing a cent. a bigger picture would help identify.
x69_x69
looks like mine alot i have a 61 qwens with a 61 johnson sea horse
