dumb boater
- Joined
- Jul 24, 2009
- 30
As my name indicates, i'm a dumb boater! This boat has been in my family since new, and I'm the 3rd generation to use it....
I know absolutely nothing about engines, and limited mechanical abilities. (I sit in an office all day). Here's what happened...out on water about 5 miles from ramp...started hearing a loud sound by the throttle. Didn't know at the time is was the overheat warning sound! Been in the boat 30 years and it never did that before...
ok, so i'm worried about getting back to the ramp so i turn around and head back. I make it back with he warning sound still going off, and of course after i get back and look at the manual, i think oh #$?#$@!@!!!!! I should have stopped right away.
I also didn't look for water coming out of the engine for cooling...just slipped my mind...put it back in the water a week later to see if the streams of water were coming out...it wouldn't even turn over. Pulled boat back out and went home. Read manual more and checked the fuse...it was blown so i relaced that. I hooked up a hose to the intakes and started the engine. It did start, but seemed rougher than usual and a little smoke was coming out by the prop. No sreams of water so I'm pretty sure I at LEAST have a water pump issue.
Sorry for the length of this post, but i'm just a dumb boater that didn't recognize the signs i should have...feel like an idiot now...
If a motor is blown, will it still start? Based on what I've indicated above, what do you think my prognosis is?
