serial # = year ????
surreyboy
hi every one . i just bought a boat with a 50 horse johnson & am not sure the year . can i tell from the serial # ? if so how ? thankx for all info
Re: serial # = year ????
if you look up a part on the web, like an impeller, put in the model # and it will post up the year. I did the same thing cause the guy that sold me my boat told me my motor was a 91 and i was looking up an impeller kit and put in the model # and it showed up as an 88.
good luck.
surreyboy
Post the model number and somebody can look it up. The serial number is pretty useless.
List of 50 HP Johnsons here:
http://web.archive.org/web/20010709223551/www.evinrude.com/docktalk/modref/jomodyr/JHP50.html
hey that list is pretty cool , thanks > i could not find the model number there though ??? the one i pulled off the motor was - J50TLCRM . the guy i purchesed it from said it was a 86 but i just want to make sure thankx again
bankerjohn
J50TLCRM
J = Johnson
50 = 50hp
T = Trim and tilt, electric start
L = 20" shaft
CR = 1984
M = model run
surreyboy
thats great !!!! thank you so much . now could someone please tell me where to find or what the mixture is for this engine is & also what type of oil to use in the leg ?? thanx again for all your help . oh one more thing , while trailering the unit should i lock the motor in a up right position with a rod or is the electric motor enough ?
cheers !!
MRamsden
Mix the gas 50:1 and use Evinrude approved oil, there is additives in there just for thier motors from what I have heard.
MRamsden
You should travel with it in the upright position. Mine is a electric tilt but it has a flip lock when it's up and you lower it down to rest on the lock. At least thats what I do.
cheers !!
