Repair a hole in the bottom of the hull
Rickairmedic
Re: Repair a hole in the bottom of the hull
With any luck if the warm weather returns to our fine town :D Ok HOT weather I hope to splash her before the end of September . I still have a long way to go she is basically a bare hull at the moment other than the transom still being in .
Rick
BassnKY
Rick:
Good luck!!! Around here, the end of September usually gives me a several good weekends of fishing.
I hope to get all the materials together this week if I can get all my Q's answered. Bass Pro has what they call "non-woven fiberglass" in stock and I have the resin. If this is the same thing as bi-ax.
The only hold up might be the paint. I am going to repaint the transom but I think a quart will get the job done. But, it being $50-$60 a quart and being out of a job, it might have to wait.
Rickairmedic
Check with these guys on whatever materials you need their parts/service department is great and they are more than willing to help ( unlike Just add water ) :D. They are right off of Zorn on river road just down the way from you :D.
http://www.mssboats.com/
Rick
BassnKY
I was planning on checking them out. St Mathews Imports (SMI) is right around the corner. They do ALL body work including boats. They repaired hail damage on a SUV my wife had several years back (The had to cut the hole roof off and replace it). But, if I remember correctly, they have their own paint department and can custom match the paint for me.
But, when the time comes, I will also check with Marine Sales. They might be able to do custom matching. After all, I do have a chip large enough. ;)
smokeonthewater
old thread dug up!
I was reading for info on patching four holes from thru hull transducers and came across this..... I see a couple of you are in louisville so I figured I'd post up to say hi and see how this turned out.
kenny33
I am from lawrenecburg about 30minutes from taylorsville lake been waiting on the water to go down to put my boat out there where was it you put the hole in it on taylorsville so I know where to watch out I am in the middle of repairing one from herrington lake now right down the center so it will be a fun one to fix
