Rangerboatman363
- Joined
- Aug 5, 2009
- 22
Well here it goes, 3 summers ago got the boat out and it wouldn't start, carried it to the shop and had to replace stator, rectifier. Got it back and it ran great.
After the first day on the lake noticed I was losing power and speed, got it home and found that the wires to the stator was not tied down and the flywheel had rubbed them and cut one into. Taped them up and sortered the broken one back together, cranked it up on water hose ran fine, took to the lake and it wouldn't plane, Highest rpm was 26-2800.
Load it up came back in, checked plugs, found bad coil, replace once again back to lake same thing. Ran out of money.
Last summer got it back out hoping to fix it and installed a CDI box and changed plugs (Champion gapped at .30) back to lake same thing. Time and money problems again.
This year started again hoping to solve the problem, several said it was in the plugs or the carbs, clean the carbs and found the 1st cylinder not getting gas, cleaned again, cylinder seems to be firing, ran and idled on water hose, we had found a port that was stopped up.
Back to the lake after several checks and though we had it fixed, put it in the water again, ran a bid then started cutting off again, wouldn't idle, tried to get it to run and if I hurried I might get it in gear and get it moving so I tried to go on plane, NOPE, 26-2800 rpms again.
Buddy of mine tried riding in the front of the boat and bouncing on it to get it on plane, if I had the room it might have got there but only got to 3200 rpm in a area the size of 2 football fields.
Old gas was drain from tanks, new installed, marvel mystery oil used and but no change.
Our next step is try a compression test on thursday night but though I would run it by everyone here to see if anyone has any ideas.
The motor never even had but 1 plug change untill 3 years ago, ever since has been trouble.
Running low again on money and about to give up....any Help? Thanks in advance.
