eph445
- Joined
- Aug 1, 2009
- 36
Hello Everybody,
I recently purchased a 14’ Duo year I believe is 1966 according to a photo of another Duo I saw pictured on http://www.theclassicboathouse.com/g...iberglass.html
The deck is going to need to be replaced. The original decking had already been removed and replaced with ?” green treated plywood which is very heavy. I was considering replacing the deck with regular plywood and covering it with a couple coats of fiberglass resin. I am also considering making this deck removable by using either ?” or 5/16” stainless helicoils inserted into the stringers in 4 places, fastened by flathead stainless screws.
Stringers appear to have been replaced also and seem to be in good shape. They were covered by fiberglass also. As you can see from the photo, each stringer is actually 2 pieces. Is this acceptable? I would think they each should be 1 continuous piece.
I figure as long as I have the hull (or bilge) exposed I may as well add a little reinforcement. Don’t know that it really needs it but I guess a layer of 1.5 oz fiberglass mat wouldn’t hurt.
Gelcoat is in dire need of repair. As you can see from the photo it is severely cracked throughout the entire boat.
Boat floats and doesn’t leak and motor runs decent, so until the snow flies I’m going to keep playing in the water. I don’t have warm shelter to work in so I’m going to do as much grinding and sanding until the snow buries me then by next spring I’ll be ready for fiberglass, gelcoat and paint.
Until then I would certainly appreciate any advice, guidance, instruction, warnings etc. All feedback is welcome. I’ve been browsing through “oops” thread http://forums.iboats.com/showthread.php?t=234392 and getting a lot of info there. Looking forward to hearing from you.
Happy Boating!
P.S. The biggest challenge right now though is getting these photos posted.
Happy Boating!
