Help Identifying Johnson Outboard
rkr29kracing
Hello All
I am new to this forum, and just bought my first boat.
When I bought the boat, the outboard was unhooked/unwired and laying in the middle of the boat. Reading the posts here has already helped me mount and wire up the outboard and check the lower drive oil.
I want to order a manual for the motor, but I need help to identify what year and how many horsepower it is. I know it is a Johnson Electric Sea-Horse and it has two cylinders. I have a photobucket link to a couple pics, but maybe someone could point me in the direction of the serial number/model code.
http://s305.photobucket.com/albums/nn204/rkr29kracing/johnson outboard/
Also, while I am waiting for the manual, can someone tell me how I know if the impeller is working properly, and what to do if it is not. I ran it for about 10 seconds, but I didn't see any water coming out, so I shut it down. I am not even sure I know where the cooling water should exit.
Thanks for the great help on this site.
Re: Help Identifying Johnson Outboard
look just above the 2 transom clamps, should be a plate with model and serial #. it is 60's ish motor.
alangf
Hello All
My guess, based on appearance is 1964 forty horsepower.
seahorse5
If the gearcase is shaped like a bullet and comes to a point, then it is a '62 to '66.
IF it has a blunt nose 2 piece gearcase top and bottom that screw together then its a '61 to '66.
The model number will tell for sure
F_R
It does not have a compression relief, that narrows it to 1962 -up. Further more, it has a hot water choke, which limits it to 1963 -down. So it is either a 1962 or 1963.
rkr29kracing
Thank you all for the help! I will check near the transom clamp to see if I can find the information and narrow down the year.
