95 Mercury 150, oil alarm and no spark one side
Robalohd
I have a 95 Mercury 150hp Carb. While out on the water last weekend I got a low oil alarm (beep,Beep...). I checked the reservoirs and found no problems. I did not run the motor. After returning, did a compression check all 6 are ok 115-117psi. I changed the fuel line to a 5gal mix 50:1 mixture and started the engine. Still getting the oil alarm, and noticed it was running rough. I checked to see if it was firing on all cylinders and found that one side was not firing (Port Side). It was using oil during the day because of the lower than full reservoir that I started with. I did notice that the engine was not smoking like normal before getting the premix into the system.
Any Ideas?
Thank you!
hondon
Re: 95 Mercury 150, oil alarm and no spark one side
You,ll likely be troubleshooting down to the warning module.Gotta love those things.Hopefully so.
j_martin
The oil alert gets it's indication that the engine is running from the #2 spark coil drive. If it isn't firing, the alarm will sound. It's all the same problem. It'll either be a switchbox or a stator. Check it out with a DVA
hope it helps
John
Robalohd
Thank you for your replys. I will be headed back down this weekend to try and find the problem.
