Electronic fuel pump install pointers
jze1212
Hi there. I recently installed a rebuilt ( by me ) later model Mercruiser Vortec style 350 into my boat. The previous engine was a 1989 Mercruiser 260hp with mechanical fuel pump. The new engine does not have the cam for the mechanical fuel pump so I have to go electric. I understand the oil pressure safety switch as well as needing a low pressure ( 5 or so PSI? ) fuel pump... Is there a pressure regulator in there? I have found a few posts here on the forums helpful but I thought I would try to get as much help as possible, being fuel and all! I have done extensive work on cars with EFI but that does not help much here! Thanks
-Justin
Bt Doctur
Re: Electronic fuel pump install pointers
no pressure reglators, it`s all in the pump.
jze1212
Thanks. Do you recommend any particular make/model pump?
Yachtsman1304
I have a 97 4.3 LX and I put a Mallory fuel pump in. Good price and good product.
JERRY J
They say timing is everything.. :)
Yachtsman1304,
Could you advise what model Mallory F/P you are using..
I am also in need for my "new" '99 4.3 vortex...
Thank You......
Yachtsman1304
My OEM pump number was 805656-1 so i replaced t with a Mallory 9-35428. It was a perfect fit and a quick job. My problem actually ended up being a combination of my anti-siphon valve at the tank and the fuel pump. Let's just say I know my fuel system real real well now!
JERRY J
Thank you, very much for the response...
I'm about to embark on learning all about my fuel system also..:)
