Re: '52' 5hp tn28
thanks. i found out that the float was stuck., so i got it free, i think. if i look up into the bottom where i unscrewed to make access to the float pin , i see a silver pin that i tapped onand now that moves freely just a bit. not sure if you should see a pin coming out of that grommet on top of the housing, i don't. before i released the float pin, gas used to trickled out of there. hopefully it is released fully.
now it starts if i put ether in. it seems it last till the ether is gone and shuts down. got to check the gap in the plug but i believe it is good. my mixture is 32:1 with super tech tcw-3 oil.(??). now if the speed mixture is that sensitive, maybe that could be a problem. the gentleman who i bought this motor from said it ran and i guess he buys engines strips them apart and fixes them and shows some. i hope there is no other problem. giving him the benny of a doubt........for now
stay tuned for chapter 2. you guys are very helpful thanks alot.
