Re: Muffs??
Running the boat under a load is much preferable to running it on the muffs. About the only thing that running on a hose will tell you, is that the motor runs.
It won't reveal one or more inoperative cylinders, unless you are very good at hearing the difference in sound that the motor will make. Most of the time, it also won't tell you if its pumping water on its own. Clutch dog condition can also be hidden, because without pressure against the prop, it will shift into forward and reverse and spin the prop, seemingly just fine.
Depending on the amount of money being asked for the boat, I would even recommend a trip to a reliable mechanic, if you are otherwise satisfied and seriously considering the purchase. A motor can seem to run well in the water too, but have a problem that is obvious to someone who knows what they are looking for. A couple of hundred bucks in shop time for a "once over" by the mechanic, could save you thousands in repair bills, on a boat that you might not have bought with such info.
As the saying goes, "buyer beware!"
