- Joined
- Mar 5, 2006
- 30,797
Re: ignition coil question
Fortuantely, the engine never gets hot enough to ignite oil. If it did, you would hear about engines blowing up all the time from their engine oil exploding!
The oil/epoxy thing is more a longevity issue and not a safety issue. If a coil fails due to vibration it won't cause a safety issue other than your boat dieing at an inopertune moment. I really challenge that as an issue anyway. Probably more vibration to the coil while the boat is on a trailer than when it is in the water. As far as longevity due to heat dissipation, one would think an oil filled coil will be able to dissipate heat better than an epoxy based one. That is why all commercial power transformers are oil filled...to dissipate heat out to cooling fins.
