switching from VRO to reg. fuel pump
rick fox
i have a 1985 johnson 120 v4 that has a vro pump on it and would like to change it to a regular pump and mix oil myself , does anyone know what pump i should get ,
Mod. J120TLCO ,, SER. G7027007
i see that 1983 140 has what looks to be a reg. pump would this one work and will it wire the same ? :confused:
any and all help apprecated thanks
rick
Re: switching from VRO to reg. fuel pump
if your fuel side is still working:
VRO conversion w/ pump still working
if the fuel side on your Pump is still working it is very simple. unplug the 2 line harness going to the oil tank, unplug the 3 or 4 wire harness, going to the Vro pump. cut and cap the oil line going into the motor. add oil to fuel tank, mix well, then remove fuel line at top carb, catching gas in a container, pump the fuel line bulb until you get premixed gas to the carb. you can tell as it will change color. put line back on carb, and go boating.
or replacements:
Vro Replacement Fuel Pump Kit "no Oil"
(for Using Oil/gas Pre-mix In Fuel Tank)
#5007422 it is in the $300 range.
$100 range you should be fine with this.
Part Number: 0385784
Description: FUEL PUMP AY
Pack 0395712,0398385,0433390,0438559Qty: 1
rick fox
i looked up that number ,,i see the pump looks much differnt that the VRO ,which i don't care as long as it get's it runining . i can fab any bracket i need so not worried there . it look's like it has a place for three hose's ? the VRO had two for the fuel and two for the oil side . also the VRO had three wire's going to it are these power or alarm wire's or both ? i am not used to boat motors are these pumps electric or are they drivin another way .
i thought that a fuel only pump would have two hose's and wire's for power but maybe i'm way off as i said i'm new to boat motors.
i just want to make sure i get it done right and get back on the water ;)
thanks rick
i had a hard time finding the number 0385784 on I-BOAT maybe i was doing it wrong :(
ezeke
All VRO/OMS and conventional lift pumps are mechanical, working off the pulse from one of the cylinders. The wiring is for the VRO/OMS alarm system which is not needed when running pre-mix.
ezeke
iboats does not sell OEM parts.
You would not want the 0385784 pump either because it is seriously out of date and would only be out of very old stock, superseded several times. Look for the 0438559 or more recent.
rick fox
ok the 0438559 pump it is . looks to be three hose conections i take it i need the in and out of gas and the other one is a pulse vacume to run it . the wire's are history with going to premix then .
so if i have it right now i'll get the pump and try to let you know when it's running thanks everyone :D
blue_streak
rick,
just curious as to why you want to remove VRO. Is it not working properly or at all?
thanks
jeff
the VRO and VRO2 oil sides, are known to fail at the wrong time. the OMS pump is much more reliable, or the premix pump.
rick fox
well the VRO pump that was on it failed all together i took it to the boat mechaic they said it was bad also. it was not pumping at all. after primeing it would run out the prime and die unless you sqeezed the primer again.
i do have a VRO pump that i replaced about 5 years ago because the oil side quit ,
in order to use the old VRO for premix i need to hook up eveything except the oil inlet hose right ? maybe i'll try that before ordering a pump. i'll try that later today
thanks
rick fox
first thanks for the help everyone ,and the info you gave me was great ,
my boat is back running with the old VRO pump with the oil not used . i will premix and run it tell it die's lol
new VRO $380 dollors which i don't need
the advise you guy's give to people to help them out ( priceless)
thank you thank you
happy boating everyone,,,,, :D :D :D
Rick
rick fox
hey guys the old pump i had that i wasn't sure of had issue's so i ordered a premix pump 0438559 ,, i have question on hose hook up
with the pump faceing my with the plastic vacume hook up near me there are the two hose conections coming out the bottom i'm sure one is fuel in and the other out , which is which ? the one on the left is slightly larger ID. is that the fuel in ?
any help would be great
ezeke
Please click the thuimbnail.
Please note that the VRO pumps were much more powerful than the conventional lift pumps. Be sure to reduce fuel obstruction as much as you can to reduce the possibilty of running lean at WOT with the conventional pump.
Single lift pumps were stock on some earlier 140HP crossflow motors but not on V4 loopers.
rick fox
ezeke,
working on it a bit more i figured out which was which on the motor and with the picture i should be able to get it hooked up thanks
,, i had address fuel restictions issue at the begining of this it got a new primme and line and the antisyphin at the tank was addresed as well so i think i have done about all i can to take care of any posible fuel restictions thanks for the head's up though :D
SparkieBoat
nice picture Ezeke..I want a 8x10 so I can frame that..better than a Divinci...lol
